Old 12-08-2017, 17:56   #1
Bennetts101
AYC Diff rebuild
Hi all
My rear ayc diff started to whine a little while back, have done a few hundred miles and its getting worse so I need to get it sorted.
Who would you lovely people recommend to rebuild it if anyone does that sort of thing? Or should I buy a low mileage second hand unit or even a new one?
Evolution VII RS
Bennetts101 is offline   Reply With Quote
Old 12-08-2017, 18:13   #2
stu8
stu8's Avatar
Car: Evo V - geekmapped.com
Dont really hear of people rebuilding AYC diffs, tends to be replace with second hand. Later 7/8/9 are said to be stronger then 4/5/6 but all will fit
Maybe worth dropping the oils first, look for swarf to confirm a failing diff.
Quick question though, what car is this for, if its a 7RS its unlikely to be an AYC diff. Rs diffs are rebuilt
Stu
Old 12-08-2017, 18:52   #3
Bennetts101
Stu
Ah thanks Stu, will hunt for a second hand one.
Oils have been dropped, not much of a show but have had used our workshops chassis ears on the car and its definitely rear diff.
The car is my 7RS but from factory was fitted with a ayc diff, its a very interestingly spec'd evo.
Evolution VII RS
Old 12-08-2017, 18:59   #4
stu8
stu8's Avatar
ahh ok, just checking
I'd personally hold out for a 8MR or 9 rear diff, newer so hopefully less miles
7/8/9 tend to be a bit more expensive than 4/5/6
Stu
Old 12-08-2017, 19:08   #5
Bennetts101
Stu
I will do, am in no real rush as she only goes out a few times a month
Am I right in thinking 8 and 9 are super ayc?
Do I need to change the pump aswell?
Evolution VII RS
Old 12-08-2017, 19:16   #6
stu8
stu8's Avatar
there are internal differences on the 8MR and maybe 9. Not sure what the difference is though. As for pump, no need to change that. Personally i'd do as I did years ago, and look for a rear diff off a standard E8 260, as thats spent its life handling less power
Stu
Old 12-08-2017, 19:25   #7
Bennetts101
Stu
Ah ok, thanks very Stu, much appreciated
Evolution VII RS
Old 12-08-2017, 23:19   #8
Clivew
Transmission Dynamics
Clivew's Avatar
Car: Highly Modded E6 T04Z/2.2ltr, E91 325D Ohlins/M3 bushes, Renaultsport Megane RS250 Cup.
Depends on what is failing in the diff. Some of the bearings are replaceable, the CWP isn't available new, so no go if it's failing. The only way to know is to remove the inspection cover from the left hand casing and have a look at the crownwheel.
Transmissiondynamics@gmail.com
Bennetts101 (16-08-2017)
Old 12-08-2017, 23:21   #9
Clivew
Clivew's Avatar
Stu
The difference between E7 AYC and E8/9 SAYC is the torque multiplier which increases the torque transfer capability of the diff.
The Following 2 Users Say Thank You to Clivew For This Useful Post:
Bennetts101 (16-08-2017), Kevin Troy (07-09-2017)
Old 13-08-2017, 01:37   #10
stu8
stu8's Avatar
I remembered you telling me something about the difference a while back, but couldnt remember exactly what it was, so took the safe option of just saying there is a difference
Stu
The Following User Says Thank You to stu8 For This Useful Post:
Clivew (13-08-2017)
Old 17-08-2017, 23:31   #11
richyx
whesn it whining too? if when you tuen corners its the clutch plate fluid that needs flushing with oil changes
richyx is offline   Reply With Quote
Old 18-08-2017, 20:51   #12
watercow
I have a EVO X SAYC diff if that any help?
watercow is offline   Reply With Quote
Old 06-09-2017, 19:57   #13
Bennetts101
Hi Rich
Whining on deceleration.
I changed all fluids 2000 miles ago when I bought it but didnt do a ayc bleed.
Evolution VII RS
Old 10-09-2017, 01:34   #14
Titan82
User
Hi don't know if it helps but I had an evo 8 rear ayc diff rebuilt not to long ago got parts I needed from Ross sport and rebuilt at torque developments at lakeside Essex
Titan82 is offline   Reply With Quote
Old 11-09-2017, 21:20   #15
Bennetts101
Fantastic, thanks Titan.
Which parts did you have to have replace?
Evolution VII RS
