Old 11-08-2017, 18:44   #1
Cyberstaff
Cyberstaff's Avatar
Car: Evo IX Fq 320, Jaguar xe R-Sport, Vw T6 kombi highline
Spark Plugs
Ive just finished making my own cop kit for my evo 9 and am ready to fit the weekend. I could do with changing the plugs at the same time.
Ive currently got NGK IR ILFR7H plugs. I was advised on NGK BR8ES plugs but i believe they are only suitable for the 7,8ect.
What pugs are people running or recommend for a 9?
Also what should i gap them to?
Evo 9 running 405/390.
I live one day at a time!
Cyberstaff is offline   Reply With Quote
Old 11-08-2017, 19:03   #2
Ads9
Ads9's Avatar
Car: EVO IX FQ320, Honda Fireblade & Nissan Navara
If you want to go a step colder (from 7 to 8) then the Denso IKH24 will do the job. I've run the 9's (IKH27) for the last few years. They're way cheaper than the NGK racing plugs which are the only other option I know of for the 9 due to the requirement of a longer plug.
I do have a new set of the 24's sitting in my toolbox I can post for £30?
Ads9 is offline   Reply With Quote
Old 11-08-2017, 23:39   #3
Cyberstaff
Cyberstaff's Avatar
What power are you running bud? How do the Denso plugs rate?
Old 12-08-2017, 16:53   #4
Ads9
Ads9's Avatar
A bit over 500hp, no issues to report.
HKS rebrand these Denso plugs and triple the price
Old 12-08-2017, 18:26   #5
Simon9300
User
Cant go wrong with NGK. I think I read somewhere of Denso plugs breaking up. Stick with NGK Iridiums
Simon9300 is offline   Reply With Quote
Old 12-08-2017, 21:27   #6
Cyberstaff
Cyberstaff's Avatar
If i stick with NGK and go one step colder they are 120 a set
Old 12-08-2017, 21:37   #7
Madevelopments
Car: Evo 6 under construction
I recommend denso ikh24.
Mark
MADevelopments
Builders of the winning Time Attack 2007 Club Class car
For all your servicing, race preparation engine conversions, suspension and 4 wheel alignment.
07768 356204
01491 411139
www.madevelopments.com
Medmenham NR Marlow Bucks SL7 2TA
Emtron Engine Management UK Distributor
Vipec Mapping
Autronic UK Distributor
Ecutek mapping
CP pistons Stockist
Carrilo Con Rods
Injector dynamics stockist
Ohlins stockist
Madevelopments is offline   Reply With Quote
The Following 2 Users Say Thank You to Madevelopments For This Useful Post:
Cyberstaff (12-08-2017), MrEvo665 (12-08-2017)
Old 12-08-2017, 21:44   #8
mlau1294
mlau1294's Avatar
Car: Blue Evo 9 (470/465), White 6RS (350/340) & Black Lancer GSR Ralliart Sportback (300/310) UK daily
I use NKG R7437-8 racing plugs on my 9 with a COP kit too
Old 12-08-2017, 21:59   #9
Cyberstaff
Cyberstaff's Avatar
Mark
Think this is what I'm going to go for.
Old 12-08-2017, 22:11   #10
Ben_r1
Ben_r1's Avatar
Car: IX MR FQ360 HKS
Don't rate Denso have had a couple misfire issues in the past that we're resolved with switching to NGK and there are horror stories of them dropping tips.
Ben_r1 is offline   Reply With Quote
Old 12-08-2017, 22:21   #11
Cyberstaff
Cyberstaff's Avatar
Are the colder race plugs worth the money though? or should i stick with stock plugs on a cop kit?
Old 12-08-2017, 22:24   #12
MrEvo665
MrEvo665's Avatar
Car: Evo X FQ400 (By WRC Developments)
Ive heard and read the exact same thing, but about the NGKs. Also ive had ngk Iridiums in the past and they have not lasted long, also they have caused misfire in a previous car.
Then ive used denzo and now the hks racing plugs and no problems. When i bought my evo it had brand new Ngk Iridiums after 2000 miles i was having slight misfire witch turned out to be a plug. Then i replaced with Hks racing plugs, driven 7k miles and no problems, still going strong.
just my 2p.
MrEvo665 is online now   Reply With Quote
Old 12-08-2017, 23:54   #13
Clivew
Transmission Dynamics
Clivew's Avatar
Car: Highly Modded E6 T04Z/2.2ltr, E91 325D Ohlins/M3 bushes, Renaultsport Megane RS250 Cup.
Why on earth would you want to go from a plug with an iridium centre and a platinum ground, to a common garden nickel/nickel plug, apart from cost?
Select heat grade to suit your engine and combustion temps, nothing else.
jmb_silvester (15-08-2017)
Old 13-08-2017, 00:06   #14
Clivew
Clivew's Avatar
The heat range of the plug has nothing to do with it being a precious metal plug. You can buy a heat range 7 race plug, or a heat range 9, £3 copper plug.
The expensive race plugs improve service life and efficiency + reliability of the spark under severe conditions in a high boost combustion chamber.
Old 13-08-2017, 07:33   #15
Ads9
Ads9's Avatar
Surely this is a Kentucky Fried Rat story?? I'm sure any plug can drop a tip, especially if it is over-tightened
I'm running a COP kit and 0.6-65mm gap at 2 bar with no issues, maybe the gap was a little wide (std 0.7mm) when you had them in yours?
