Old 19-05-2017, 18:37   #1
wha77t
Car: evo 8 MR340 and Subaru RA v limited
Evo 8 fuel pump help please😩
Hi guys... Really need some help and advice please.. I have a 2004 Evo 8 MR.. I went to Manchester today and on way back home I heard the famous loud whine from the fuel pump.. I found it strange as its new. And has barely covered 100 miles.. My last pump did the same at 100 miles so I got a new one and this is doing same.... As soon and I joined motorway it started spluttering and hesitating and wouldn't go over 3k revs.. Car always has a full tank and all the fuel pumps have been walbro... Any idea what it could be? Fuel pump? Relay? Battery? Thanks
wha77t is offline   Reply With Quote
Old 19-05-2017, 20:54   #2
sbn1979
Hi
sbn1979's Avatar
Car: Evo 6 Tommi Mak
Who fitted it?
sbn1979 is offline   Reply With Quote
Old 19-05-2017, 21:43   #3
wha77t
I did... But before I bought car it was spot on so I changed pump cos it started to whine and wouldn't start sometimes.. And all new pumps are doing same after 100 miles
Old 19-05-2017, 21:47   #4
sbn1979
Hi
sbn1979's Avatar
where did you buy it from?
Old 19-05-2017, 21:47   #5
sbn1979
Hi
sbn1979's Avatar
Also did you put the plastic collar on from the old pump on the new pump?
Old 19-05-2017, 22:34   #6
wha77t
Yeh put everything in.. If I had done it wrong wouldn't it have played up straight away?
Old 19-05-2017, 22:34   #7
foreskin fred
You're not going to fault find it without a pressure gauge.
Just tell yourself over and over again "I've been conned".
Eventually it'll sink in.
foreskin fred is offline   Reply With Quote
The Following User Says Thank You to foreskin fred For This Useful Post:
wha77t (21-05-2017)
Old 19-05-2017, 22:56   #8
sbn1979
Hi
sbn1979's Avatar
What tends to happen if you miss that collar out is that they will drive off boost ok, though unknowingly be lean, the minute you try boost you have a lean misfire
Old 19-05-2017, 22:57   #9
sbn1979
Hi
sbn1979's Avatar
Also if you've fitted the big black rubber spacer at bottom?
Old 19-05-2017, 23:08   #10
wha77t
Yeh I double checked
Old 19-05-2017, 23:09   #11
wha77t
Could a weak battery cause it.. I don't tend to use it alot and sometimes I've had to get boost pack to start it..
Old 20-05-2017, 07:34   #12
sbn1979
Hi
sbn1979's Avatar
Think you should start doing basic checks now like voltage to the pump and/or pressure if you have the facilities, if not get it into a specialist.
The Following User Says Thank You to sbn1979 For This Useful Post:
wha77t (21-05-2017)
Old 20-05-2017, 07:36   #13
Evo6er
Evo6er's Avatar
Car: EVO 8 MR
Have you checked your fuel line all the way back to the fuel rail?
Palma Red EVO 8 MR FQ320 no.81# RG Maintained
Evo6er is offline   Reply With Quote
The Following User Says Thank You to Evo6er For This Useful Post:
wha77t (21-05-2017)
Old 20-05-2017, 14:14   #14
Picko
Picko's Avatar
Hard wire it and put a walbro 255 in and it'll do it anyway
Picko is offline   Reply With Quote
The Following User Says Thank You to Picko For This Useful Post:
wha77t (21-05-2017)
Old 21-05-2017, 18:08   #15
CJP93
User
CJP93's Avatar
Having the same trouble with mine at the moment... Drives fine off boost but as soon as you go to put your foot down it just coughs and farts, Very loud whine aswell
Luckily Iv got a spare standard pump in the garage, Should I be alright fitting the pump even though it's been sat around for awhile????
Evo 8 MR FQ320 Running @376BHP BMW 3series M-Sport
CJP93 is offline   Reply With Quote
