Old 18-05-2017, 22:34   #1
Ben_r1
Ben_r1's Avatar
Car: IX MR FQ360 HKS
Reusing old flywheel with new clutch?
I've changed many clutches on many cars over the years, but with the exception of a few DMFs have always reused the standard flywheel without skimming it.
Looking at clutch options for a change over summer and I've noticed a lot of performance clutch manufactures state warranty will be void unless you have proof of skimming the flywheel.
When did this become necessary? Has anyone ever experienced issues of re using the original flywheel on a new clutch?
This is obviously assuming the flywheel is inspected for obvious damage and cracks etc.
Obviously don't want to fork out for a new flywheel unless it's essential.
Ben_r1 is offline   Reply With Quote
Old 18-05-2017, 23:03   #2
kikiturbo
Car: EVO 9 GSR
unless it has really bad heat spots you can re use it without any trouble..
Old 19-05-2017, 05:50   #3
Ben_r1
Ben_r1's Avatar
Well I can't see any reason as to why there'd be heat damage the car gets a very easy life and the clutch is fine at the moment, just changing as a precaution more than anything.
Old 19-05-2017, 09:04   #4
war-machine
war-machine's Avatar
as long as its a genuine flywheel
skim it to make sure surface is 100% flat and true
were not taking too much material off the flywheel
have it inspected and checked by someone who deals with flywheels
Old 19-05-2017, 10:31   #5
kikiturbo
Car: EVO 9 GSR
I did it both ways... on my car, without skimming and on another 450 bhp car with no skimming.. worked fine but both flywheels did not have much heat damage.
if you skim it, which is not a bad idea, make sure you are having it ground flat and not cut on a lathe... as this will just ruin the flywheel..
On my car, due to driving it gently in city with OE replacement exedy, or OE fly, I had some deposit build up on the fly, which made the car judder a bit when going from full stop in first gear with very low revs... Usually the deposits would clear of with a quicker start..
Old 19-05-2017, 14:24   #6
Gavalar
Car: Evo 9 fq360 Mr
Flywheel is cheap so just change it to a lightened one when you do clutch mate
Gavalar is offline   Reply With Quote
Old 19-05-2017, 14:31   #7
Evo6er
Evo6er's Avatar
Car: EVO 8 MR
Precaution? Clutches you replace when you destroy them or you spit your release bearing out. Why would you bother otherwise???
Palma Red EVO 8 MR FQ320 no.81#
Evo6er is offline   Reply With Quote
The Following 2 Users Say Thank You to Evo6er For This Useful Post:
evo/nut (19-05-2017), JOHNDQ (19-05-2017)
