Old 17-05-2017, 14:25   #1
Evo Parts Ireland
Evo Parts Ireland's Avatar
Evo 5rs underside restoration and fresh spec
Bought this last year off rob Dunphy after I sold my tme mak rs that's also on here is the restoration witch I also did the underside of now the plan was for this rs was to do a fue track days befour the car changed and new spec so after a few track days I desided to sell.off the unwanted parts I wasn't going to use ect engine turbo intercooler kit ect
Video of it when rob owned it and there lots of videos of it japan doing gymkhana https://youtu.be/lSR9D9KRZnw
It's spec is as follows
Type C 17×9 et28 Front et40 rear 5mm spacers all round
255/40/17 Yokohama ADO8R tyres
Evo 8 GSR brembo calipers
Carbon Lorraine RC6 pads
Dixcel brake discs
Project Mu handbrake shoes
APP braided brake lines
Ohlin coilovers
Cusco pillow ball top mounts
Cusco front ARB
Cusco rear ARBpillar
Cusco front adjustable droplink brackets
Cusco Version 1 lower front brace
Cusco Version 2 lower rear brace
Cusco 3point front brace with Brake cylinder stopper
Cusco 3point rear brace
Mines rear brace bars
oem RS boot brace
Jspeed flitch braces
Jspeed lower braces
Cusco skid under gaurds
Cusco fuel tank gaurds
Ralliart suspension bushes
Cusco twin plate clutch kit
Evo 8rs short ratio box with long final drive and Cusco VCU
Cusco RS front diff
Evo 9rs rear diff with Cusco MZ 2way LSD
Ralliart rear diff mounts
dcuatro ge1 ground effector under side spoiler for down force
Exterior
Varis carbon hyper canards
Varis carbon oil cooler guide
Varis carbon air guide
Carbongoodies d-style carbon sideskirt extensions
Carbongoodies d-style carbon rear bumper extensions
Ganador mirrors
Bootlid lip spoiler
Carbon exhaust surround
Sigma Carbon pillar trims
Engine
Evo 7 for MKSports Japan GK specification
Jun baffled sump
Remapped ecu with launch control
cusco engine and gearbox mounts
Greedy intercooler hard pipes
Greedy alloy intake pipe with K&N filter
Greedy Intercooler core
HKS Oil cooler kit
HKS Oil thermostat
HKS SSQV
HPI Turbo elbow
Fujitsubo downpipe
Apexi High flow sports cat
Fujitsubo RM01 cat back exhaust
Coil on plug kit
SARD fuel pump
Tomei plug cover
Cusco catch can
Cusco cooling panel
Polished rocker cover
Ralliart Oil and rad caps
Jspeed manifold heatshield
Jspeed thermostat housing
Billion rad hoses
Interior
Bride Carbon Kevlar Zeta 3’s seats
Bride passenger seat rail
Weistera super low down drivers seat rail
Do luck floor brace
Takata 4 point harnesses
Carbon rear view mirror cover
Carbon Mitsubishi motors gearknob
Sparco steering wheel
Blitz SBC boost controller
Billion water temp gauge/ fan controller
Defi BF gauges
FET turbo timer
Rigid clutch peddle rubber
Intercooler spray button behind accelerate peddle
Ralliart foot rest
carbon heater surround
carbon gauges surround
arc titanium gear knob
Carbon door cards
Carbon cluster surround
Now the new spec is a norris designs 2.2ltr engine stage 3 head Tomei pro cams 270 11.5mm lift ect (1200bhp)
Norris full vband turbo set up
Magnus inlet manifold
Norris intercooler kit
S90.throttle body
Id1300cc injectors
Cosworth fuel rail
SARD fpr
Rs gear (mite fit a 4.11)
Twin plate
Ross sport Raduim fuel.pump set up twin 044 pumps
Link g4+ supply fitted and mapped bye norris On ethanol fuel.mix with Irish fuel
Pics befour and up to the stage I'm. At now
Evo Parts Ireland is offline   Reply With Quote
The Following 3 Users Say Thank You to Evo Parts Ireland For This Useful Post:
evolover21 (22-05-2017), Mita (17-05-2017), squeakyclean32 (18-05-2017)
Old 17-05-2017, 15:14   #2
Robbo777
Very impressive spec list there Paul that certainly isn't going to be a low budget build, the underside has cleaned up very nicely, I'm looking forward to your progress on this one.
Robbo777 is offline   Reply With Quote
The Following User Says Thank You to Robbo777 For This Useful Post:
Evo Parts Ireland (17-05-2017)
Old 17-05-2017, 15:29   #3
Evo Parts Ireland
Cheers pal ye I agree it won't be a low budget pal but as I see it I'll be keeping this for meself as iv always wanted a 5rs and now I have it so I'll do my best on this restoring the underside has fue stone chips on spare wheel well but hopefully once cleaned it won't be to bad so I can clear coat the full underside and then 3m stone chip the wheel Archs in white lots to be done yet to it be a case of over a year doing it right with all new parts engine wise
Old 17-05-2017, 15:34   #4
Robbo777
On something like this you take your time, do it once and do it right.
Old 17-05-2017, 15:50   #5
Evo Parts Ireland
Exactly pal fact ��
Old 17-05-2017, 18:19   #6
Mita
Are you leaving the factory stone chip on? And clear over that and factory primer/paint?
Old 17-05-2017, 18:53   #7
M3 ROB
M3 ROB's Avatar
Car: Evo 6 TME,
Very impressive keep the updates coming
M3 ROB is offline   Reply With Quote
The Following User Says Thank You to M3 ROB For This Useful Post:
Old 17-05-2017, 20:53   #8
Evo Parts Ireland
Yes pal I'm. Leaving factory stone chip and give it a fue coats of clear and waxoyl it also
The Following User Says Thank You to Evo Parts Ireland For This Useful Post:
Mita (17-05-2017)
Old 17-05-2017, 20:55   #9
Evo Parts Ireland
Will.do pal thanks will be a long process as I'm. Fussy and want it 110% and have lots of faith in Simon at norris designs so.ill.have a cracking engine setup too so fingers crossed all goes to plan
M3 ROB (24-05-2017)
Old 17-05-2017, 21:01   #10
Mita
It does look very clean. Fair play mate. Are you doing that to stay original? Or more because you don't feel it needs it?
What will you do with the rust that you do have?
I'm (very slowly) doing mine, it's minty mint underneath except some stone chips that have light rust in them. But one thing I have found is paint that looks perfect on the outside actually in places underneath had rust, only bits but it was still there.
Old 17-05-2017, 21:03   #11
Mita
BTW what have you cleaned underside with? Thinners?
Old 17-05-2017, 21:05   #12
Liam_d
Liam_d's Avatar
I absolutely love this thing!
Liam_d is offline   Reply With Quote
The Following User Says Thank You to Liam_d For This Useful Post:
Old 17-05-2017, 21:11   #13
Evo Parts Ireland
A few more pic of the engine bay toothbrush clean with the help of my young lad Paul jnr
evolover21 (22-05-2017), J90ELB (19-05-2017), squeakyclean32 (18-05-2017)
Old 17-05-2017, 21:11   #14
willox
willox's Avatar
Car: Evo 7 Rs,Porsche Cayenne,Bmw M2
Like this 5rs,trick looking car and she looks an absolute gem underneath
willox is offline   Reply With Quote
The Following User Says Thank You to willox For This Useful Post:
Old 17-05-2017, 21:11   #15
Evo Parts Ireland
A toothbrush and g6 compound
The Following 2 Users Say Thank You to Evo Parts Ireland For This Useful Post:
