Old 17-05-2017, 14:02   #1
tazzi
Link G4 vs standard ecu remap??
what's the pros and cons of the link over the standard ecu? Are there gains to be made by the link bhp wise that can't be made by the standard ecu??
When aiming for 450bhpish will the link stand a better chance of achieving better figures?
Evo 9 gt!
tazzi is offline   Reply With Quote
Old 17-05-2017, 14:21   #2
sbn1979
Hi
sbn1979's Avatar
Car: Evo 6 Tommi Mak
Stock ecu will do that no problem, the link will have better motorsport features, link is a great aftermarket ecu vs £££
sbn1979 is offline   Reply With Quote
The Following 2 Users Say Thank You to sbn1979 For This Useful Post:
Grant620 (18-05-2017), tazzi (17-05-2017)
Old 17-05-2017, 14:23   #3
sbn1979
Hi
sbn1979's Avatar
Also choose what ever your mapper is happiest working with
The Following User Says Thank You to sbn1979 For This Useful Post:
tazzi (17-05-2017)
Old 18-05-2017, 07:59   #4
foreskin fred
Link knock control doesn't work properly.
Stock is infinitely better.
http://forums.linkecu.com/index.php?...plug-in-evo-6/
Funny that nobody seems to know that the stock evo knock sensor is a resonant type and has a frequency of about 12KHz.
That's if you understand what the gods are saying in the link.
Just tell yourself over and over again "I've been conned".
Eventually it'll sink in.
foreskin fred is offline   Reply With Quote
Old 18-05-2017, 09:19   #5
sbn1979
Hi
sbn1979's Avatar
It's actually 13, if you the windowing and threshold table is set right you shouldn't have issues
Sim92 (18-05-2017)
Old 18-05-2017, 09:23   #6
sbn1979
Hi
sbn1979's Avatar
Though I agree stock has decent knock control it also has its limitations, especially with internal noise, at least with the link you can define these areas
Old 18-05-2017, 13:36   #7
foreskin fred
It's actually just under 12 KHZ.
Where did you get the 13 from?
You just made it up?
Old 18-05-2017, 13:50   #8
sbn1979
Hi
sbn1979's Avatar
Course I made it up If you don't know why it's 13 that's your problem
Old 18-05-2017, 15:09   #9
Mita
So if you were forging for example then OE knock control could pick up noise?
Evo 5 Rs 5 year build
sbn1979 (18-05-2017)
Old 18-05-2017, 15:34   #10
Rampant
Profound thinker
Rampant's Avatar
Car: IX FQ-320: GT1s, COP, Rods, LinkG4+, MR lip & has the devil in it (& 996 C4S: exhaust)
Yes this is an issue - the stock ECU is calibrated against a standard engine. Change *anything* and the knock control may start picking up random noise as knock. Whether it be tappets, cams, a stiff lower engine mount, etc, etc, and definitely if you change the characteristics of the rotating/reciprocating masses - all the "different" noise can induce the stock ECU to retard the timing even if you don't have knock.
I am very, very pleased with the Link G4+ and is one of the best mods I've fitted, even though it doesn't release any more "Power" from my standard-ish engine. It runs it noticeably smoother and the MAF is removed as well and mapped on boost sensor without the need for complex/time consuming VE mapping on the standard ECU.
I'm pretty sure a competent mapper could map in the knock control if required, it needs proper windowing (crank angle sensor window for each cylinder) and background noise settings mapped in, and if mapped properly will detect knock and retard the ignition timing on a single cylinder as opposed to the standard ECU retarding on all 4 cylinders for any single cylinder knock detection. It has to said, though, that a decent mapper wouldn't be mapping a dangerous map that required knock control on the understanding that you always use decent fuel, etc. Twin maps is useful as well for a valet map, low octane fuel map, or just pops,n,bangs....
Yours Aye
Mark H
Je cherche l'orgasme d'auto
J'ai trouve l'orgasme d'auto
C'est une evo IX bleu par le Rountree
The Following 2 Users Say Thank You to Rampant For This Useful Post:
Mita (18-05-2017), sbn1979 (18-05-2017)
Old 18-05-2017, 15:51   #11
tazzi
What other features are you using via the link?? Anti lag?? Launch control?
How is the boost changed from high to low, isnthere a controller of via the water spray
UOTE=Rampant;5777485]Yes this is an issue - the stock ECU is calibrated against a standard engine. Change *anything* and the knock control may start picking up random noise as knock. Whether it be tappets, cams, a stiff lower engine mount, etc, etc, and definitely if you change the characteristics of the rotating/reciprocating masses - all the "different" noise can induce the stock ECU to retard the timing even if you don't have knock.
Yours Aye
Mark H[/QUOTE]
Evo 9 gt!
Old 18-05-2017, 16:08   #12
Rampant
Profound thinker
Rampant's Avatar
Extra features?
MAF removed - load mapped via boost.
Closed loop boost works perfectly fine for me.
I have true sequential ignition on my Coil-on-Plug setup.
And pops'n'bangs via a second map via the ICS Auto switch. Second map is basically the same boost and timing as the main map except for the low load for mortar and machine gun fire
My Mrs calls me a child. I agree. It's hilarious.
That is all I need. Perhaps Open Loop boost control would be a very slight enhancement and knock control could be mapped, but for my road car I don't deem it as a necessity since I always use Nitro+ or Momentum fuel.
Yours Aye
Mark H
sbn1979 (18-05-2017), tazzi (18-05-2017)
Old 18-05-2017, 17:21   #13
4g638
The G4 is an excellent ecu. I run an old school power fc d- jetro which I've converted to the pro version by changing the eprom. I've been running this for the last 11 years. In the future I will change to the G4. So going from an ecu that has no knock control whatsoever to one that has knock control per cylinder along with all the rest of the features like individual fueling, sequential firing order instead of the wasted spark one,offering a much newer software yet simple enough and a much faster cpu than the stock ecu and power fc offers, will be awesome for me as I do my own mapping.
An excellent ecu is not the one that offers the most extra features of the type of anti-lag, launch control, but the one that offers the most features in the best version of them for someone to fine tune a setup in the best way possible.
Marios
" Go tell the Spartans,passerby,that here by Spartan law we lie. " Leonidas I son of Anaxandritas II and king of Sparta,really proud to be his descendant!
4g638 is offline   Reply With Quote
The Following User Says Thank You to 4g638 For This Useful Post:
Old 18-05-2017, 17:37   #14
sbn1979
Hi
sbn1979's Avatar
How come you want to go open loop boost control?
Originally Posted by Rampant View Post
Extra features?
Yours Aye
Mark H
Old 18-05-2017, 18:06   #15
Rampant
Profound thinker
Rampant's Avatar
Compensation for atmospheric conditions...
(If I wasn't selling the car I'd get it mapped in.)
