Old 20-03-2017, 12:22   #1
dan.h
Engine oil for 2.3 stroker
Hey everyone, I'm sure this gets asked all the time and I've scrawled the internet and read a fair bit on here but I'm still to make any of my own conclusions.
I had a 2.3 stroker engine built by Evotune last year and I've probably covered around a 1000 miles since its been run in and mapped. It is running 10 60 millers cfs oil and I bought some more in case it needs any top ups.
Im thinking of putting it on the road around June time so will probably have it serviced again just before I start to use it.
I've been reading a lot about this oil and other types and some people say its too thick others say its fine. Trouble is although the engine has been built over a year its done very little miles. I don't want to cause any problems by changing the grade of the oil. I fully trust what oil Jamie has supplied but you know what its like when you start reading into things its just set my mind ticking away.
Car is currently running 460 bhp on lowish boost so future plans are get the actuator sorted and push my s205b turbo harder or opt for a hta 30 turbo kit. So north off 500 the car will be running.
I know usage is important so I would say road use and if I'm lucky the odd track day.
Thanks in advance guys.
2.3 evo 6
dan.h is online now   Reply With Quote
Old 20-03-2017, 12:38   #2
Kevin Troy
Kevin Troy's Avatar
Car: Mitsubishi Evolution VIII
Send a message via Skype™ to Kevin Troy
I'd first ask the engine builder what he would recommend. Al tho I think you should stick with current 10W60 oil.
I use in my 2.3 Stroker 15W50 Motul 300v.
"Strive for perfection in everything you do.
Take the best that exists and make it better.
When it does not exist, design it."
Kevin Troy is offline   Reply With Quote
The Following User Says Thank You to Kevin Troy For This Useful Post:
dan.h (20-03-2017)
Old 20-03-2017, 13:02   #3
2+barplease
2+barplease's Avatar
Car: RVR Evo 6.5 2.0 L/R by Norris Designs
I have a 2.0 LR by Norris and I use Fuchs Titan Race Pro R - 15/50
Forged RVR Evo 6.5 380/400 @ 1.6bar on SD
2+barplease is offline   Reply With Quote
The Following User Says Thank You to 2+barplease For This Useful Post:
dan.h (20-03-2017)
Old 20-03-2017, 16:04   #4
dan.h
Thanks guys, I know it's decent oil I'd just read a few statements where by people had said it was a bit thick. Obviously just wanting to protect my new engine and wondering what other people use or have used in the past.
2.3 evo 6
Old 20-03-2017, 17:44   #5
wozzy
Tuners on here will recommend oil grades ranging from what you've got down to 5w40. Who's right and who's wrong? Who knows lol. I would say as long as it's a good quality ester fully synthetic you won't go far wrong but best to ask the person who built your engine as they are the ones guaranteeing it
Bye bye evo. Hello BMW family wagon
wozzy is offline   Reply With Quote
The Following User Says Thank You to wozzy For This Useful Post:
dan.h (20-03-2017)
Old 20-03-2017, 19:56   #6
martyn21487
martyn21487's Avatar
Car: Blue mak and 5rs
I use 10/60 in mine and it's fine
martyn21487 is offline   Reply With Quote
The Following User Says Thank You to martyn21487 For This Useful Post:
dan.h (20-03-2017)
Old 20-03-2017, 21:32   #7
dan.h
Thanks guys,
I'm using what has been specified with the engine and sounds like that's absolutely fine.
TBH with the evo it's not something I'd given much thought to as thats what was supplied when I picked the car up after mapping. I have no problems with the type of oil it's using either just read a few things lately that made me wonder.
Thanks everyone for your help.
2.3 evo 6
