Go Back   Mitsubishi Lancer Register Forum > Technical > Tyres / Wheels
Old 07-01-2017, 13:07   #1
ddavej
ddavej's Avatar
Staggered Wheels On An Evo
I've got a set of Rays CE28n wheels off my 350z that I fancy putting on my Tommi Mak just for a change for the summer.
They are 19's but 10.5" on the rear and 9.5" on the front, any suggestions on tyre size to keep the rolling circumference the same?
ddavej is offline   Reply With Quote
Old 07-01-2017, 14:10   #2
vinyard
vinyard's Avatar
Car: 2 Evo's gone, now C63 estate and R1
I wouldnt think they will fit being that width without arch mods, but if your gunna try a 30 or 35 profile would proberly be needed and the handling/ride would be crap
vinyard is offline   Reply With Quote
Old 07-01-2017, 15:18   #3
Peadar
Car: Evo 9 GT
You'll rip your diff apart no matter what size of tyres you put on!
E92 M3 / Evo 9 GT / A4 Black Ed
Peadar is offline   Reply With Quote
Old 07-01-2017, 15:25   #4
Trev-the-Rev
Car: V1 RS450 Extreme.
^^ This. The AWD system will be destroyed.
http://www.psychoontyres.co.uk/a-psy...extreme-rs450/
Never run out of track, grip and ideas at the same time
Trev-the-Rev is offline   Reply With Quote
Old 07-01-2017, 15:45   #5
ddavej
ddavej's Avatar
Okey dokey, I'll stick with the standard wheels then
I've got 2 Maks and have only got this up, running & mapped after nearly 2 years so I'd like to at least use it for a while without further grief
I very much appreciate the replies, I'll leave the wheels on the 350z!!
Old 07-01-2017, 16:14   #6
Darkman
Darkman's Avatar
Car: Evo 7
I've ran staggered wheels on an Evo 7 for 2 years without issues m8 lol
Darkman is offline   Reply With Quote
Old 07-01-2017, 16:41   #7
plip1953
Phil
plip1953's Avatar
Car: Evo X 300 SST
An then what happened?
Phil
Old 07-01-2017, 16:49   #8
H18BY0
... now with more Bang :)
H18BY0's Avatar
Car: Slagged Red Evo 6 tme (ex 6 silver tme owner) & 95 white Astra Merit (auto :)
they fell off . . .
:::::::::::::::::::::: Tommi Mäkinen ////////// Edition No.13 ::::::::::::::::::::::
_______________________________________________________________________
::::::::::::::::::::::: Car has front lights, brake lights and features MAGNATRACTION ™ v
H18BY0 is offline   Reply With Quote
The Following User Says Thank You to H18BY0 For This Useful Post:
plip1953 (07-01-2017)
Old 07-01-2017, 18:38   #9
Darkman
Darkman's Avatar
Car: Evo 7
Never had any issues with it...what with the wise ass comments?? Giving the guy factual info and not telling him **** like he will wreck his diff or gearbox!! Worse case his car will handle poor depending on setup!!
The Following User Says Thank You to Darkman For This Useful Post:
ddavej (07-01-2017)
Old 07-01-2017, 18:49   #10
plip1953
Phil
plip1953's Avatar
Car: Evo X 300 SST
Were you running anything like 19" x 10.5" rims? They're crazy too big on an Evo
Phil
Old 07-01-2017, 19:25   #11
Trev-the-Rev
Running the same or very similar rolling radius is ok but any degree of difference spells trouble.
Old 07-01-2017, 19:30   #12
Darkman
Darkman's Avatar
Car: Evo 7
19x9.5 rear and an 19x8.5 front no issues whatsoever -2 camber front and 1.5 rear handled well!!
Old 07-01-2017, 19:53   #13
Trev-the-Rev
The wheel diameter and/or geo settings won't influence the loads on the transmission - its unequal rolling radius that's the problem
Old 07-01-2017, 20:29   #14
Darkman
Darkman's Avatar
Car: Evo 7
Not entirely true!! Excess camber will cause the transmission to work at incorrect angle and will put strain on it!! Rim diameter really won't matter a toss unless you stick 24" rims on something on it lol
Old 07-01-2017, 21:16   #15
ddavej
ddavej's Avatar
I've run staggered on a few gtrs in the past, I think the biggest were 18's though. It was something like, from memory, 275/35/18 rear and 245/40/18 fronts. The rolling circumference was the same so caused no issue, I've also run a couple of STi's but on 17's.
These all arrived from Japan like that, I've put 19 rears and 18 fronts on a few of my NSX but of course these are just rwd not 4wd
All opinions appreciated!
The Following User Says Thank You to ddavej For This Useful Post:
Darkman (07-01-2017)
