#46 | |
gary nevile pure incest
"How do you say Garçon in Chineese?" |
#47 |
Regional Organiser
#48 |
Car: VII GSR, Ti zorst, ECUflash, ECU+, 3 port BCS, meth injection, BC coilovers, K Sport brakes.
For all the agro of doing it yourself, just take it to Rich at RGs. No skinned knuckles and you know it's done right. He can map it as well.
On the brakes get the hoeses done, makes a huge difference to the feel, and PF or Carbotech pads. PF are a bit more ear freindly. |
#49 | |
Senior Citizen
#50 | |
Senior Citizen
Nice one for that, they make it look easy ![]() |
#51 |
Evo-less again :(
Yes he can - does a damn good job as well
My car was ECUTekd by Rich before i got it.How about an alternative suggestion Matt. Dont spend 2k, instead just get yourself a fuel pump, Gizzmo boost controller, some braided brake lines, decent brake fluid and some decent pads. Then go get a Geek to remap her. Will save you money that you can pay for fuel / servicing and the difference will be huge. Forget changing turbos and cams, save the money for day to day costs - therefor freeing up money for other things! A holiday as an example! Only suggesting this as you mentioned it yours daily drive ![]() Rob
#52 |
The Filth
The IX turbo is over rated imo. I am yet to see one out perform my 8mr turbo on the road? Save your money and get a 10.5 hotside(£200ish) for your existing turbo. Plus save money again and get some MR cams(£100ish), again on the road GSC's and HKS 272's are not worth the extra money. Forget boost controllers, get a 3port solenoid a fuel pump then map it to 1.75, you should see close to 300atw.
You should have quite a bit of change left to get some PF.10 brake pads(£140ish) and new standard disks(130ish) Spend the rest on yourself |
#53 |
Car: 2.4ltr on the way oh yes!!!
mat you could buy my old catch tank cusco very shiny 40quid would stop det when you up the boost stops that nasty oil vapour going in & cloging things up have a forge recert too if you want it holds @ least 1.6 bar as for rich he is good nothing is out of the question his putting me 2.4 lump in hopfuly when its done so i dont get spaner rash lol
big al
#54 |
If I was in the OP's position I would do the following:
1. Get a fuel 255 pump. You can fit that yourself 2. Buy a second hand turbo. Either a Evo 9 80 series, S204 or FP Green. Keep your existing turbo incase you have any problems. 3. Ebay turbo elbow. 4. HKS 272 cams and adjustable pulleys. These come up for sale on the forum every now and again but you'll have to be quick. These cams are fine on stock springs. With the mileage on your motor you should get the cam belt changed when the cams are done. 5. Wideband such as LC1 6. A boost gauge or display to monitor boost. 7. Spend a lot of time learning about Ecuflash and Evoscan. Start adjusting timing and fueling in small steps. 8. Get a 3 port solenoid and start upping the boost. |
#55 |
Car: Evo V - geekmapped.com
if it was my money, i wouldn't bother with the 9 tubby, just get a 10.5 hotside, i also missed a 3 port boost solenoid off my earlier list. But being a 260 engine i would change the cams. Standard cams off a 260 become very restrictive after 350 hp, and changing them transforms the engine
As for RGMotorsport, another +1 from me ![]() Stu
Moses aka Samurai Motorsport - samuraimotorsports@hotmail.com CPP Motor Developments - www.cpp-motor-developments.co.uk RG Motorsport - www.rgmotorsport.co.uk LTS Performance - http://www.ltsperformance.co.uk/ Insured by Keith Michaels. |
#56 | |
Get out while you can.
#57 | |||||
Senior Citizen
Just had a holiday Rob, nice suggestion, but they're definitly over rated, why the **** does it take so damn long to get anywhere these days? Left my house at 3:30 a.m and arrived at the villa in Crete at 16:00 local time which is 2 hours ahead of us, I was shafted after all that! ![]() Quote:
![]() Also, would a tuner such as RG be happy to install 2nd hand parts if I decided I'm too much of a chicken to do the work myself? I just thought last night that there might be a few tuners opposed to doing this, understandably of course. Quote:
![]() Quote:
I don't really know anything about that side of things and I don't have any mates to call on for help and advice, I know there are people on here who offer tonnes of help and advice such as now, but I couldn't afford to wait for a response to a thread if I make a hash of things ![]() Quote:
![]() Thanks to everyone by the way, I really appreciate everyone's input |
#58 | |
Change the standard cams only for GSC S1 and got 358bhp/380lbft With the budget he has and not being able to do the cams himself i just don't see the point in the outlay for the return. I repeated the test on my current engine set up. Again all that was changed was cams this time with springs and retainers swapping from 1st Gen GSC S1 to Kelford 272 and gained an extra 4.2 bhp peak and 5lbft with a smidgen gain in the mid range torque curve. Again i have to question if it's worth it for the gain especially as this guy is not on a massive budget. I've seen reported 380 to 390 lbft on standard 260 cams at 1.8 bar. I think it would be better to spend £180 or less on adjustable cam pullies.
Turbos are like computers, every other month there old technology and out of date. Last edited by Andy_8 : 02-09-2009 at 10:43. |
#59 | |
In comparrisson, the 260 has the mildest cams (evo 4 to 9 that i know of) so if you want over 350, cams are earlier on the list If you want i can dig out some RR graphs, the car was same spec for both when i was getting the gems ecu i had at the time mapped, the only difference was the second map had GSC S1 cams, fidanza pulleys and 10.5 hotside not only was there good power gains, but the area under the power curve was greatly improved Stu
#60 | |
(hopes my memory serves me correctly as it was a few years ago )Stu
| Thread Tools | |
