Go Back   Mitsubishi Lancer Register Forum > Marketplace > MLR Platinum Option Trader: Ross Sport
Thread Tools Rating: Thread Rating: 12 votes, 5.00 average. Display Modes
Old 11-01-2017, 16:19   #136
OEM Parts Guru
Gav@RossSport's Avatar
Originally Posted by leeslancer8 View Post
Are stuff like the anti squeal shims you sell online compatible with the fq400 calliper?
Also are the little circular blanks available to buy which push into the outside of the calipers?
I have no idea on the shims, as generally speaking, if your using a brake kit, squeal is no concern, but if they are pad shaped,the Brembo ones will not wrok on an Alcon pad shape, blanks, can you send me a picture?
Gav@RossSport is offline   Reply With Quote
Old 11-01-2017, 16:24   #137
leeslancer8
leeslancer8's Avatar
Car: EVO 8 260 - EVO 7 RSII - EVO 8 FQ320 MR - EVO 4 GSR
Will do by shim I meant anti rattle spring apologies the ones in my brakes have seen better days wanting to refurb to as new
Will try and get a photo. Thanks
leeslancer8 is offline   Reply With Quote
Old 11-01-2017, 16:28   #138
OEM Parts Guru
I see, yes the spring will be compatible.
The Following User Says Thank You to [email protected] For This Useful Post:
leeslancer8 (11-01-2017)
Old 14-01-2017, 17:22   #139
devilmaz
I found only 2014 prices.
How much now for evo x front advantage kit 365x32.
devilmaz is offline   Reply With Quote
Old 14-01-2017, 19:56   #140
Ross W
Ross Sport
Ross W's Avatar
Car: 8.75 @ 163
Send a message via MSN to Ross W
All current prices are on our website
Ross W is online now   Reply With Quote
Old 19-01-2017, 18:50   #141
devilmaz
Thank you for your reply.
Is the price on the website for the MLR club?
The kit advantage extreme 6pot is the same for all evo4-9 change only the disc or also the bell etc? I mean if I buy now the option 343 will I be able than to upgrade to 365 purchasing what?
Will it cost me more to ask for an other color?
Old 02-04-2017, 16:17   #142
Aquaman
Hi
Does the RACE brake system fit the EVO 9 Plug & Play or does the hole have to be unscrewed?
I now have an advantage rear and a new race without handbrake
Thanks for the answer
Aquaman is offline   Reply With Quote
