Old 19-05-2017, 21:01   #31
Rampant
Profound thinker
Rampant's Avatar
Car: IX FQ-320: GT1s, COP, Rods, LinkG4+, MR lip & has the devil in it (& 996 C4S: exhaust)
Originally Posted by Clivew View Post
My post wasn't a 'which is the better diff' it was replying to Ivicas post on the strength of the AYC diff. I personally think for a road car, and for most people, the AYC diff is better,
Understood what you meant in your post. = Not everything is black and white.
Again, I totally agree with you. AYC was fitted for a good reason.
All the best
Mark H
Je cherche l'orgasme d'auto
J'ai trouve l'orgasme d'auto
C'est une evo IX bleu par le Rountree
Old 20-05-2017, 00:27   #32
alpinaturbo
Although few have seen AYC diff successfully used in race cars with big Evo 4G64 on E85,
Here is the spec of the successful TA Evo that after winning, finally crashing - donated its AYC to another race car still using it today.
https://professionalawesome.com/car-...modifications/
alpinaturbo is offline   Reply With Quote
Old 20-05-2017, 00:43   #33
alpinaturbo
Top JDM TA Evo uses AYC
http://www.speedhunters.com/2015/02/...9-time-attack/
Old 20-05-2017, 04:47   #34
strange_days_uk
Simon - EVO V
strange_days_uk's Avatar
Car: EVO V 2.3 Stroker
RS vs AYC
Great thread guys
Clive - how do you think a ayc diff will hold up in a V running 500bhp? Road use only.
502/480
strange_days_uk is offline   Reply With Quote
Old 20-05-2017, 05:20   #35
alpinaturbo
Strange Days UK
I'll test it for you:
bolting up 7163 T4..500bhp turbo on pump fuel.
Will also run E85..and that should ad 50bhp.
If it breaks...I'll be sad.
The Following User Says Thank You to alpinaturbo For This Useful Post:
strange_days_uk (21-05-2017)
Old 20-05-2017, 06:45   #36
kikiturbo
Car: EVO 9 GSR
hell I'll run one too..
kikiturbo is online now   Reply With Quote
The Following 2 Users Say Thank You to kikiturbo For This Useful Post:
alpinaturbo (20-05-2017), strange_days_uk (20-05-2017)
Old 20-05-2017, 08:23   #37
Benja
If you guys say that the ayc is better for racing like time attake hillclimb road race etc.. why anyone figured out how to make the ayc case stronger and relaible for high hp an torque like the guys at the hillclimb sceen that reach with them Evo's to 700/750 bhp, .?
Benja is offline   Reply With Quote
Old 20-05-2017, 08:30   #38
Mita
Somebody has
Mita is online now   Reply With Quote
Old 20-05-2017, 09:08   #39
Benja
I'm asking because I planing to build my e9 for hill climb and I considered the rs diff as premier option, and if you guys says that the ayc has more benefits it's taking me back for considering what is more good to use.
I saw 2 links one with profetional awsom that use evo x rear diff... apparently can take more torque( but who knows how to fit/if there is any need)
2. The G force garage from japan use the oem rear diff with 570 lbft of torqueonly with flash...
Any thoughts ..?
Old 20-05-2017, 09:14   #40
stu8
stu8's Avatar
Car: Evo V - geekmapped.com
Well it use to be said on here that the 8 and 9 (and maybe 7, not sure) ayc diff was stronger than the earlier evo rear diffs. Not sure why or if its true, but cliveW is the guy that can give you the best advice
Stu
Old 20-05-2017, 09:20   #41
Mita
As Stu said Clive is the man to speak to. He manufactured a new AYC casing (his own design) on his E6 .
Any thoughts ..?
Old 20-05-2017, 10:26   #42
kikiturbo
Car: EVO 9 GSR
I think clive runs a plate diff in that casing of his..
problem with ayc is not just the casing but the fine gears inside which can also break.. the circuit racers that used to run a AYC diff had a external cooler for it (which should be used for prolonged circuit use)
for sure, in race use RS is the one to have (or other plate diff), properly setup and this is where Clive can work his magic.. it is a proven solution. Making a 700+ hp hillclimb car with AYC diff might be interesting but then be prepared to do a lot of development, both mechanical and with ACD/ayc ecu, to make it work well.. however this might be just too much for a privateer... I mean, the current PP record holder runs plate diffs and no center diff.. IIRC..
Old 20-05-2017, 10:44   #43
Mita
http://www.lancerregister.com/showth...ghlight=CliveW
Post 15 I stand corrected
Old 20-05-2017, 10:50   #44
super rover
acting daft since 1969
super rover's Avatar
Car: E7 RS RALLY CAR
problem now is AGE at best your only going to get a rear diff thats 10 years young at worst 15 years ,its had a life its been hammered to with in an inch of its life all its life
bunging 2 or 3 times its normal horse power through it and expect it to play nicely is only going to be a lottery
"Of all the branches of men in the forces there is none which shows more devotion and faces grimmer perils than the submariners."
Sir winston churchill
super rover is online now   Reply With Quote
The Following 2 Users Say Thank You to super rover For This Useful Post:
Clivew (20-05-2017), kikiturbo (20-05-2017)
Old 20-05-2017, 10:51   #45
Clivew
Transmission Dynamics
Clivew's Avatar
Car: Highly Modded E6 T04Z/2.2ltr, E91 325D Ohlins/M3 bushes, Renaultsport Megane RS250 Cup.
Originally Posted by strange_days_uk View Post
Great post guys
I think it will break sooner rather than later. If you're not worried about that happening, then just use it until it does. You'll then have real world experience, and can chip in on future discussions with authority!
The Following 2 Users Say Thank You to Clivew For This Useful Post:
Rampant (20-05-2017), strange_days_uk (20-05-2017)
