Old 11-01-2017, 09:29   #16
infamous pa
Car: Evo 6 tme
Originally Posted by Red Rooster View Post
Good luck with the project .. you've made a decent start and it will be well worth it when finished !!
As for removing the underseal I really recommend treating yourself to a MBX surface preparation tool . They aren't cheap at about £350 but are really really good at removing the horrible black stuff ! They kind of self clean and don't get gummed up . I used one on the underside of mine before it was blasted as believe it or not blasting just pushes the underseal along like a lump of sticky chewing gum !
I'm still using it for cleaning other bits and bobs up prior to painting !
Can't wait to see your progress !
I had a little play with the grinder wire wheel attachment last night as it was playing on my mind and it comes off quite quickly as I got quite a bit off in a matter of seconds so I'll try using this arrangement to begin with.
Like you say there quite pricy but thanks for the advice and if I start to struggle then its another path I can take thanks
infamous pa is offline   Reply With Quote
The Following User Says Thank You to infamous pa For This Useful Post:
Red Rooster (11-01-2017)
Old 11-01-2017, 10:01   #17
infamous pa
Car: Evo 6 tme
Well this is how she sits for now as I'm back off to work
I've had a look up the chassis box section and once again I don't think its looking to bad, this is the worst one and its not really that bad so I'm just glad its coming apart and not just falling apart
probably the worst corrosion on the car as of yet is on the front cross member under the radiator but its still treatable, ill post some more pictures of it once its been stripped back.
I'll continue the stripping down once I'm back and I would like to hope that I will have it completely stripped, up on the spit and the under body stripped back and treated with Rust Bullet.
Old 11-01-2017, 10:32   #18
thetyrant
Brake Guru!
thetyrant's Avatar
Car: BMW 135i Coupe - Previously: Evo9-FQ360, Evo5-RS + 2 x Evo2's, all gone but not forgotten.
Looking good , i would probably replace the front lower cross member as if its anything like the one i changed on my old Evo2 it will be a lot worse than it looks at first glance!, due to the design its a real water trap and rust starts deep inside inbetween the seams.
They are cheap enough to buy from mitsi or rosssport etc and not that bad a job to swap over.
Ian
MLR Sprint Series Class A champion 2013 and 2014- Powered by and stopped by Carbotech
Contact me for the best deals on Carbotech High Performance Brake Pads,
MOTUL RBF600 Brake Fluid and also Stainless Hose kits
thetyrant is offline   Reply With Quote
Old 11-01-2017, 10:33   #19
David86C
David86C's Avatar
Car: EVO VI TME - Stock(ish)
Nice garage you've got there mate!
Keep the good work! Can't wait to see the results!
How is the engine? Any concerns/plans in there?
Cheers,
TME
David86C is offline   Reply With Quote
Old 11-01-2017, 12:54   #20
infamous pa
Car: Evo 6 tme
Cheers,
The engine has always been ok but could do with a tidy up so that will be getting a dose while it's out.
I'm not looking at increasing the power as it's already running 350 ish.
If anything I'll be putting it back to the factory spec of 280 and run it's completely factory.
Old 11-01-2017, 13:09   #21
David86C
David86C's Avatar
That sounds like a clever move! Specially for the value of the car
No stripes though? I think it is the first Pink TME that "I've seen" without the stripes...!
TME
Old 11-01-2017, 13:49   #22
bails
User
bails's Avatar
Love the plain red TMEs, will be following this, looks a very tidy car to begin with too.
bails is offline   Reply With Quote
Old 11-01-2017, 18:03   #23
Peterwickett
User
Very nice
Peterwickett is offline   Reply With Quote
Old 11-01-2017, 21:21   #24
skinz
I recommend an MBX as well, I use one at work when removing under seal
Tidy looking motor.
skinz is offline   Reply With Quote
The Following User Says Thank You to skinz For This Useful Post:
Red Rooster (12-01-2017)
Old 11-01-2017, 22:03   #25
evocop4
Horizon chaser
Car: Black Tommi Makinen 310bhp; Black Focus ST 270bhp
Is this possible to do without a ramp? Every time one of these threads come up I have hope that it may be a non mechanic having a go in a normal single car garage. I want to have a go myself and would call myself a home mechanic. I got an impact wrench for Xmas in anticipation for this project.
I love lamp!
evocop4 is online now   Reply With Quote
Old 11-01-2017, 22:17   #26
JRecardo
Car: Evo V GSR
Good start on the project, will be reading with interest as you go along. Car looks quite tidy to be starting with, unfortunately I'll be needing a fair bit of cutting and welding done on my 5.
Entirely possible in a home garage, I've seen plenty of threads here of people getting the car up on stands and getting to work. It's not as comfortable, but definitely can be done.
JRecardo is offline   Reply With Quote
Old 12-01-2017, 06:47   #27
infamous pa
Car: Evo 6 tme
Yeah it was never in bad condition but it certainly needed a bit of TLC before there's any major problems.
Old 12-01-2017, 06:53   #28
infamous pa
Car: Evo 6 tme
As Jrecardo says it's very possible to do at home in a single garage as there is loads of threads on hear where people have done it on axel stands and produced amazing results.
I would recommend a set of axel stands with the highest support height though to give you the best acces to the under body.
Old 21-01-2017, 18:34   #29
M3 ROB
M3 ROB's Avatar
Car: Evo 6 TME,
I don't know how I missed this, great work so far, keep the updates coming also subscribed
M3 ROB is offline   Reply With Quote
Old 28-01-2017, 12:28   #30
Uncle Winnet
Car: white evo v gsr forged 2.0L engine
looks nice can i ask how much the lift was how do u find it for woking on the car
Uncle Winnet is offline   Reply With Quote
The Following User Says Thank You to Uncle Winnet For This Useful Post:
mitsubeastie (03-03-2017)
