I am please to announce I now have the ecutek mapping software for the Mitsubishi range so will be offering stage 1 packages and mapping for the evo range covered buy ecutek.
Private road ? I'm led to believe road is better. However I may be starting a debate with that one. Have you used Ecutek before? How does it compare to mapping with an aftermarket?
Yes I have. A good aftermarket ecu like the ones I use are definitely easier to map as that's the way they have been set up to be.
I map a race spec ecu for a racing truck series that is just the worse thing ever to use and add quite a bit of labour to map even though it's meant to be a cost capped series :blah:
Ecutek has a sensible interface
Mark
Related Threads
Lancer Register Forum
5.7M posts
86.3K members
Since 1999
