banks.myzen.co.uk/88570008release.zip
Includes ROM, full xml, PC application.
Contains my stage 1 maps for 3" exhaust, Walbro, airbox mod, external boost controller. Although I run higher baud rate on MUT and higher fuel pressure I've put these back to standard.
Includes:
Stage 1 tuning - modified lean spool thresholds, closed loop transitions, MIVEC, fuelling, timing, low load timing offset modification, knock slightly desensitised at 2500 RPM to avoid warm up false knock.
Speed density using stock sensors, can unplug and remove your MAF
Adjustable knock control
High speed DMA logging
Live map editing of all alt maps plus speed density VE tables
Knock tracing over ignition map
Tephra mods - flashing CEL on knock, intercooler spray mods, switchable maps, 1 byte load logging (used to map trace)
Enjoy. Always test for knock and wideband AFR. Use at your own risk, but I have fully tested this one.
Includes:
