i don't have a gta, but if you could identify whether the forth plug is solely for a/t control, it'd be a safe assumption that the other 3 would be identical to the e8 wiring diagram. if not, you'd need to trace the whole loom or electrically test the individual wires.
Long shot but did you figure out what this was for?
My pinouts list it as an empty spot, but it looks like the stock MAP sensor goes there. Interested as I want to log boost with a 3 bar MAP sensor (JDM Evo 7 ECU)
Ive got a 1997 rvr running the evo5 motor, wanting to run an evo5 ecu. with evo6 turbo and a front mount intercooler.
I have bin told i have to change sum or the pinout points. i would not have a clue wea to start. Help would realy be apperceated.:smthumbup
Can you please tell me if there are some differences between JDM 9 RS pin out and EDM 9 GSR pin out?
Did somebody tried to see the differences between USDM and EDM or JDM in terms of pin out?
I have a HYDRA EMS from US to install it on a EDM 9 GSR car and I have the pin out from HYDRA for a USDM 9.
Any chance you can post ACD/AYC ECU pinout and Wiring Diagram?
I am loooking to convert an Evo 6.5 RS2 to ACD, using OEM AYC computer plug location and upgrading to ACD/AYC Computer + later model Pump with connection for both ACD and AYC
hii please i wasnt to ask about the ecu codes....now i have evo 4 but when i check out the ecu i found it block plastick and MR420403 and i want to know which ecu is this for ....evo 4 or 5 or 6 ? and how could i know my engine is 4,,5 or 6 ?
Usually Evo4 ECU is metal cased, the 5 and 6 have a black plastic case, as far as engine type is concerned, look on here for a thread re engine numbers and compare your engine number to see what type you have.
Where is the rpm pin for instal turbo timer on evo 8 mr
Thank you
Related Threads
Lancer Register Forum
5.7M posts
86.3K members
Since 1999
