We can offer the following service parts on a next day delivery
Please call 01945 580066 with your requirements :smthumbup
All Apply to Evo Evo 4-10 (unless otherwise stated)
Set of 4 Spark Plugs Evo 4-8
OEM Mitsubishi Plugs £24.00
NGK BPR8ES: £12.00
NGK BR8EIX £32
NGK BR9EIX £34
Set of 4 Spark Plugs Evo 9
NGK ILF7H £55
NGK Racing R7437-8 £145
NGK Racing R7437-9 £145
Denso Racing IKH22 - £65
Denso Racing IKH24 - £65 (heat range 8 equivalent)
Denso Racing IKH27 - £65 (heat range 9 equivalent)
Set of 4 Spak Plugs Evo X
OEM Mitsubushi Plugs £75
Evo IV-X
Oil Filters
OEM Oil Filter £9.00
K&N Gold Oil Filter £15.00
OEM Sump Plug Washer £0.95
Engine Oil:
Motul Motion 14W40 Mineral Oil (Running in oil):5l £22
Motul X-Cess 5W40 Fully Synth 5l £33.50
Motul Sport 5W50 Fully Synth 5l £50.00
Motul 300V Competition 15W50 Fully Synth 6l £80.00
Gearbox Oil
Motylgear 75W90 4l £40.00
Motul Gear 300 4l £70.00
Motul Gear Comp 4l 75w140 4l £105 (Recommended for dog boxes)
Diaqueen SSTF-1 (1l) for Evo X SST Boxes - £32.40
Transferbox Oil
Motul 90PA 2l £16.00
Motul Gear Comp 75w140 1l £36 (Recommended for highest protection)
(AYC) Rear Diff Oil
(RS) Rear Diff Oil
Motul Gear 300LS 1l £22.00
AYC Hydraulic Fluid
Motul Multi ATF 1L £9.50
Brake Fluid:
Motul RBF600 0.5l £15.00
Motul RBF660 Factory Line 0.5l £20.00
Antifreeze
Motul Inugel 5l £22.00
Motul Mocool additive 0.5l £15.00
Evo 4-9 Timing Belt Kits:
Option 1: Genuine Cam Belt, Idler & Tensioner Pulleys: £115
Option 2: Genuine Cam Belt, Idler & Tensioner Pulleys + Hydraulic Tensioner £230
Option 3: Genuine Cam Belt, Idler & Tensioner Pulleys + Hydraulic Tensioner + Balance Shaft Belt £260
Option 4: Genuine Cam Belt, Idler & Tensioner Pulleys + Hydraulic Tensioner + Balance Shaft eliminator Kit £285
Other Items:
Balance shaft tensioner pulley £42
HKS Timing belt £160
Greddy Timing Belt £170
Gates/Cosworth Blue Kevlar timing Belt £155
OEM Evo Lower plastic timing belt cover: £60 Inc VAT
Evo 4-9 Brake Components
E5-9 Front Brembo Discs - Genuine - £120
E5-9 Rear Brembo Discs - Genuine - £120
E5-9 Hawk HPS Pads (Front Brembo) £110
E5-9 Hawk HPS Pads (Rear Brembo) £75
EvoX Hawk HPS Pads (Front Brembo) £110
EvoX Hawk HPS Pads (Rear Brembo) £75
E5-9 Hawk HP Plus Pads (Front Brembo) £130
E5-9 Hawk HP Plus Pads (Rear Brembo) £90
EvoX Hawk HP Plus Pads (Front Brembo) £130
EvoX Hawk HP Plus Pads (Rear Brembo) £90
E5-9 Hawk 9012 Blue Pads (Front Brembo) £215
E5-9 Hawk 9012 Blue Pads (Rear Brembo) £120
HEL: Braided Brake Line Kit: £50
Evo 4-9 Sundries:
Evo 4-9 Dip Stick: £15
Evo 4-6 Water Pump £130
Evo VIII Water Pump £185
Evo 4-8 HT Leads £55
Evo 4-8 Ralliart HT Leads £125
Evo 4-9 Standard Oil Cap £12
Evo 4-8 Oil Filter Housing £125
Evo 9 Oil Filter Housing £135
NGK BPR8ES: £12.00
NGK BR8EIX £32
NGK BR9EIX £34
NGK ILF7H £55
Evo IV-X
Oil Filters
Engine Oil:
Gearbox Oil
Transferbox Oil
(AYC) Rear Diff Oil
(RS) Rear Diff Oil
AYC Hydraulic Fluid
Brake Fluid:
Antifreeze
Other Items:
Evo 4-9 Sundries:
